CEL light help.
Old Mar 6, 2010 | 01:32 PM
got00rice's Avatar
Default CEL light help.
ok i just pick up a integra and it has the jdm cluster gauge. when i turn the ignition on the CEL doesnt come on for 5 second like how it suppose to. so i thought that previous owner probably took out the bulb for the CEL. i switch it with a usdm 97 gsr cluster gauges and made sure all the bulb was there and working. when i turn the car on the CEL doesnt come on either. so now i dont know if i have any CEL on. are there suppose to be a wire leading into the ecu for the CEL? if so it'll be helpful if anyone can help. by the way the integra is a 95 LS and the motor is swap into a 97 GSR motor. if that helps. one thing also the ecu tag that tells which ecu it is has been remove from previous owner so i dont know which ecu im running either.
japek
Mar 19, 2010 08:34 PM
mtkhalid
Jun 26, 2008 03:07 PM
sheBangZ
Aug 31, 2006 06:02 PM
LSpimpTEC
Jul 29, 2004 09:09 PM
