CEL codes 9 and 22
Old Nov 5, 2007 | 01:22 PM
OBDII Integra's Avatar
Default CEL codes 9 and 22
just got these 2 codes come up, ii'm not familar with either of these codes, i did check in the topic for what they mean which was VTEC pressure valve, and CYP cylidner sensor...i have not heard of this..any solutions or reasons why it could be throwing those codes?...thanks guys
Old Nov 5, 2007 | 03:11 PM
Default Re: CEL codes 9 and 22 (OBDII Integra)
anybody??
Old Nov 5, 2007 | 06:17 PM
any info would def help.....
Old Nov 5, 2007 | 06:26 PM
T-Mo's Avatar
Code 9 is " No. 1 cylinder position" so possibly the distributor is going bad
Code 22 is "VTEC electronic pressure switch IDK???
Old Nov 5, 2007 | 06:32 PM
T-Mo's Avatar
I searched for the actual code name and got more results
Most ppl with code 22 recently put swaps in and had to switch some wires, computers, etc..... Good luck
Old Nov 6, 2007 | 08:36 AM
Default Re: (T-Mo)
could it be more than the distributor.....here is a list of things that are going on with my car....lots of hesitation in between 40-60...after a maybe 2000 miles i strat to burn alot of oil and i dont knwo why...when i mash into my car and i hit vtec and bring it all the way up in rpms... smock comes out of my car and it starts to really smell bad...the list of mods i hvae is...4-1 header..2.5" cat welded to a catback apexi N1...and a professional products intake manifold...basaiclly the problems started after i put these parts on...at this point i'm stumped...i talked ot one of my friends and he mentioned something about a valve adjustemnt which has never been done on the car and i hvae 95k miles on it...anything would really help me...i wish i had a another car to use but this is my only car and def cant afford for it to be out of commission...thanks guys
Old Nov 6, 2007 | 09:15 AM
Default Re: (OBDII Integra)
anyone?
Old Nov 6, 2007 | 05:18 PM
any info would help
Old Jan 20, 2008 | 09:48 AM
FSS13foxtrot's Avatar
i am throwing code 22 as well and i took it off, took a look and it all looks normal, then i rewired it where it was flawed, still throwing the code, and vtec doesnt kick it, i replaced my vss, if your vss isnt working right then your guage cluster wont read the mph or km/h correctly and vtec will not kick in, after i replaced my vss i still got the messed up speedo, it is either the cable or the actual cluster itself, if this doesnt resolve it then im going to replace the vtec pressure switch as a whole. ill keep you posted on it, hope i gave you some ideas.
saintbhts
Jun 12, 2013 09:43 PM
aZnjCC
Oct 16, 2005 03:18 PM
spoonfedGSR
Sep 26, 2003 02:31 PM
Fuster_Cluck
May 15, 2003 10:05 AM
