CEL codes?!..
Old Jun 7, 2006 | 04:52 PM
VTECth1s's Avatar
Default CEL codes?!..
just got my LS/VTEC teggy diagnosed, its throwing codes 7 & 14, TP sensor and IACV, the scanner indicated TP sensor volt should be at 0.50v at closed throttle and the scanner read my car at 0.04v, so i know i have low voltage, don't know how to fix that, and I also need to fix the IACV. And help would be appreciated on fixing both, I pretty much have idle issues and car stalling randomly, and a slight oil leak coming from the dizzy, possibly a bad o-ring. Thanks!
Modified by egg6vtak at 6:50 PM 6/7/2006
Old Jun 7, 2006 | 06:27 PM
tegSimple's Avatar
Default Re: CEL codes?!.. (egg6vtak)
CEL codes...
http://www.team-integra.net/se...D=493
how to fix your iacv...
http://www.team-integra.net/fo...earch
Old Jun 7, 2006 | 07:06 PM
VTECth1s's Avatar
Default Re: CEL codes?!.. (tegSimple)
very helpful with the IACV "how to", i don't i think i need to replace it, hopefully it just needs to be cleaned. Thanks!! big help!
Old Jun 7, 2006 | 07:21 PM
VTECth1s's Avatar
**** is a tight squeeze, just went to look at it, i can barely see the front, only the sides, i assume you gotta feel around?
Old Jun 9, 2006 | 08:51 AM
tegSimple's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egg6vtak &raquo;</TD></TR><TR><TD CLASS="quote">**** is a tight squeeze, just went to look at it, i can barely see the front, only the sides, i assume you gotta feel around?</TD></TR></TABLE>
that you do.
Old Jun 9, 2006 | 12:08 PM
VTECth1s's Avatar
Got it, gonna do everything asap
lsv6137
Sep 23, 2011 09:02 PM
kinkyintegra
Jan 8, 2007 01:56 PM
B00ST2nR
Apr 18, 2003 04:03 PM
pelotudo
Oct 31, 2002 03:45 AM
