CEL: code 9 on my DA
Old Apr 10, 2011 | 08:03 PM
vtecdc4's Avatar
Default CEL: code 9 on my DA
hey guys i just bought a b16a3 DA i dont really know specifics on it yet besides it has (i think) a p28 ecu chipped with neptune. so i am getting code 9 which is cylinder postition censor.
just wanna know how to start on this, car feels normal on the most part maybe a shudder here and there. if someone could let me know things i should check to pin point the problem thatd be awesome
thanks h-t
Old Apr 10, 2011 | 08:08 PM
TaffetaEj6's Avatar
Default Re: CEL: code 9 on my DA
Do you know how many other threads there are on this subject? Google search does wonders...Are you just being lazy? anyways this is useful info i found in an instant for you even though this thread should be locked...
This is what it says the cyl sensor detects the position of the no.1 cylinder as the bases for the sequential injections. The tdc sensor serves to determine the injection times of each cylinder. The tdc sensor is also used to detect engine speed to read out the basic discharge duration for different operating conditions.
Most 1990 vehicles, incorporate the tdc sensor,cyl sensor and crack sensor in a single assembly. The function of these components does not change, but if any single sensor is defective, the entire distributor be replaced as an assembly.
Basically its all in the distributor I would say check your cap and rotor check the ignitor these are all in the distributor. These parts can be bought at an auto parts store for under 20 dollars. Except the ignitor. If this doesn't work try a friends distributor from a b-series if his works than you need a new distributor. The other sensors they speak of are on the camshaft so there not in plain sight thats why you cant find them. You cant check them either unless you want to take your valve cover off
Old Apr 10, 2011 | 08:32 PM
vtecdc4's Avatar
actually i work full time and i am also a student,
so time is really short. i am studying as of now and was gunna check it at 2:00pm tommorow but decided to take a quick peek. ill check the dizzy thanks man
Old Apr 13, 2011 | 01:51 PM
TaffetaEj6's Avatar
thats cool, if the dizzy checks out ok, and indeed one of the sensors is effed, i would suggest using google search w/ code 9 b16 in it, and it pops up hellsinkie threads from h-t, hondaswap, and other civic/honda forums and they will have very usefull information for you from other people that had the same problem...good luck man
leonardsmith
Honda CR-V & Element
Dec 1, 2021 06:33 PM
seanyboy
Aug 27, 2007 12:24 PM
OBDII Integra
Sep 27, 2005 12:57 PM
94turbohonda
Aug 21, 2004 04:31 PM
