CEL code 7
Old Dec 25, 2009 | 01:28 PM
jdm_vizionz's Avatar
Default CEL code 7
I have a 94 Integra LS and we yanked out the motor and threw in my jdm B18c with a chipped p72. But after the swap, we started it up and the CEL Code 7, which is the Throttle Positioning Sensor, came on. So, I just bought a brand new TPS sensor to replace it but I'm still waiting for it. Does anyone know if it's the tps sensor or is it the wiring? I was told it might just be the wiring but it can also be the sensor.
Old Dec 25, 2009 | 01:31 PM
Pimpsherm2009's Avatar
Default Re: CEL code 7
u need to use a obd 1 ecu p72 or a step down harness, it is prolly lookin for the 1994 tps sensor, what year is the engine?
Old Dec 25, 2009 | 03:03 PM
mouab18c1's Avatar
is it calibrated?
Old Dec 25, 2009 | 07:23 PM
The engine is a 95 sir-g with a chipped obd1 p72.
Old Dec 26, 2009 | 05:15 PM
well is it a real JDM b18c because if thats the case did you happen to get the same 95 obd1 p72 ecu with it?
Old Dec 26, 2009 | 06:35 PM
I'm pretty sure it's the same ECU. It came with the CRX that we yanked it outta. Everything is OBD1.
Old Dec 26, 2009 | 07:09 PM
ok it is a possibility u have a clitch in the ecu or the chip I would try to replace the chip and run it with a stock p72 chip or try a different ecu?
darrenVT
Engine Management and Tuning
Apr 7, 2017 04:07 AM
Krazy613
Apr 27, 2016 04:51 AM
Frany
Sep 2, 2015 07:40 AM
EgB18c406
Jun 1, 2015 05:24 PM
Cynical 1
May 15, 2012 01:41 AM
