CEL code 7 & 14?!...
Code 7(TP Sensor), Code 14(IACV), is what came up on the diagnostic test, so far i removed and clean out the IACV, seemed a little better, but still had the idle issue, now i need to get the TP Sensor fixed. For the TP Sensor, the ecu reader/scanner read a low voltage of 0.04V at closed throttle, and standard reading is suppose to be 0.50V at closed throttle, how do I adjust the TP sensor to be at 0.50V or at least close enough? If it can't be adjusted or fixed, will i need to get a new one? Also forgot to mention, is there a CEL code for the FITV, or is it in conjunction with the TP Sensor and would it just need cleaning, or a replacement, or don't touch it at all? Thanks!
Modified by egg6vtak at 9:38 PM 6/9/2006
N1NjA TuRtLE
12
Jun 5, 2004 08:30 PM
