cel code 22 vtec oil pressure switch
Old Aug 7, 2009 | 10:03 PM
NVMYDC's Avatar
Default cel code 22 vtec oil pressure switch
alright heres the deal,i origiinally had a 94 integra ls and swapped a 99 jdm b18c-R into it..everything seems to be running normal until i hit vtec...when i engauge vtec sometimes it throws a cel of code 22...it doesnt do it 1st-3rd gear as often then higher rpms. i checked the vtec solennoid and its nothing clogging, oil pressure good..when i engauge it some days its fine but others, right after i engauge it it throws a cel any ideas on why it would to that?
Old Aug 8, 2009 | 07:57 AM
NVMYDC's Avatar
Default Re: cel code 22 vtec oil pressure switch
bump!!! anyone?
Old Aug 8, 2009 | 02:56 PM
NVMYDC's Avatar
come on man i know someone out there has to know the answer to this!! pleasse!@!
Old Aug 8, 2009 | 03:08 PM
suspendedHatch's Avatar
JDM engines don't have VTEC oil pressure switches. This will prevent you from going into VTEC if you're using a USDM ECU. You'll need to splice the VTEC oil pressure switch wire on the ECU side to the VTEC solenoid wire.
Old Aug 9, 2009 | 08:50 PM
NVMYDC's Avatar
i believe i do have one its on my vtec solenoid the green plug...bump anyone else!!??
Old Aug 10, 2009 | 02:14 PM
chayce's Avatar
this could be as simple as running the wrong oil weight best to use 5 30 but i would also check the oil pan it may have gotten crushed a little and be restricting the pickup tube
94wip
12
Jun 20, 2024 07:23 PM
chue_li
Jul 9, 2006 10:36 PM
cioli
12
Feb 26, 2006 08:31 AM
drudy
Aug 26, 2005 12:20 PM
mister2racer
Jun 26, 2005 07:13 PM
