CEL 90?????
Old Sep 27, 2008 | 09:12 AM
6042nr's Avatar
Default CEL 90?????
I have a 2000 GsR that had some J00 itr pistons and ctr cams installed about 350 miles ago on the car... and after the installation the car has never idled the same. On cold starts it goes up to 2k rpms and once I hit the throttle it goes up to about 2300rpms and stays there. If I drive it even after the engine is warmed up its still at 2k rpms. If i turn off the engine when it is warmed up the car will idle fine at 800 to 1k rpms. until making a stop then it will idle up and down 700 rpms about three times then act normal. The car however does not pick up like it should... seems like somethings holding it back. It gave me CEL's at first which were all four cylinder misfires so I reset the ecu and still it idles the same. Reset the ecu a couple of times and drove it for 100 miles and now its throwing out a CEL code 90(Evaporative Emission Control System Leak Detected). Any ideas of how to go about getting my car up and running right will be greatly appreciated and sorry about all the writing...........
Old Sep 28, 2008 | 01:31 AM
OneJDMSiR2's Avatar
ctr cams or camgears? had CEL code 90 before and fixed it but don't remember how i fixed it??... try checking your sensors and wires/plugs?
Old Sep 29, 2008 | 08:37 AM
6042nr's Avatar
Default Re: (OneJDMSiR2)
CTR camshafts and Buddy Club cam gears...
Old Sep 29, 2008 | 09:24 AM
SuzukaBlueAP2's Avatar
Default Re: CEL 90????? (6042nr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6042nr &raquo;</TD></TR><TR><TD CLASS="quote">Any ideas of how to go about getting my car up and running right will be greatly appreciated and sorry about all the writing...........</TD></TR></TABLE>
find the leak in your EVAP system.
were any of the emission devices removed for the cam install?
Old Sep 30, 2008 | 07:43 PM
6042nr's Avatar
Default Re: CEL 90????? (SuzukaBlueAP2)
sorry bro... but whats an EVAP system???? and we didnt remove anything at all just put things back the way they were supposed to be.........
92bseries
Dec 7, 2011 12:59 PM
Tyson
Oct 10, 2011 08:18 AM
tazeat
10
Dec 3, 2008 09:28 PM
rlwturbosi
Aug 7, 2005 05:44 PM
eternal21
Nov 13, 2001 09:28 AM
