cel 15
Old Feb 8, 2009 | 02:48 PM
CR-V-tech's Avatar
Default cel 15
hey guys i have a 95 integra that i just swapped an f22 into and i wired in the resistor box, the car starts and runs fine but im getting a cel code of 15, ignition output signal. can anyone tell me what this, is it for the tachometer? any help is greatly appreciated thanks
Old Feb 8, 2009 | 08:11 PM
CR-V-tech's Avatar
Default Re: cel 15
ok so i googled this and i found that it's probably the dizzy, or the ignitor in the dizzy, the car wont start now so i believe it's not getting spark, as well it has a bad main relay. but the main relay is only killing the fuel because the pump is hard wired, but googled topic also said the main relay could cause this problem also. so who knows it looks like i have a few problems to fix now. this sucks cause after i wired the resistor box in it started and ran fine, we started it probably a dozen times too! idk we'll see! if anyone has any input i would appreciate it!
Old Feb 9, 2009 | 06:04 AM
CR-V-tech's Avatar
Default Re: cel 15
bump
Hondatechnoobi
May 1, 2015 08:02 PM
94civiccpe
Jul 18, 2013 07:48 PM
Hondaciv866
Aug 19, 2012 02:01 AM
stunn'd
Jul 11, 2008 06:37 PM
thirteen20CRXSi
12
Jul 3, 2006 07:27 PM
