car pulling to the right
Old Oct 4, 2003 | 08:08 PM
GSR4sho's Avatar
Default car pulling to the right
well when im driving down the road my car pulls to the right...do u guys think its my alignment or what
Old Oct 4, 2003 | 08:09 PM
King_j's Avatar
Default Re: car pulling to the right (GSR4sho)
hmmm, yes its the alignment.
cough up the $60 or whatever and get it done.
Old Oct 4, 2003 | 08:52 PM
Tweakmeister's Avatar
could be torque steer if it's when you are accelerating.
could be alignment
or...could just be the road. most roads are crowned to encourage water run off. I'd say if it happens in the left lane too then it's probably alignment.
Old Oct 4, 2003 | 09:02 PM
iH8RICERZ's Avatar
Default Re: car pulling to the right (Tweakmeister)
my car does that as well....definatly an alignment issue
Old Oct 4, 2003 | 09:08 PM
n0 iNTegRiTY's Avatar
Default Re: car pulling to the right (iH8RICERZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ &raquo;</TD></TR><TR><TD CLASS="quote">my car does that as well....definatly an alignment issue</TD></TR></TABLE>
word
Old Oct 5, 2003 | 01:46 AM
Sukebei Oni's Avatar
no. could be a tire pull. or even a brake problem. try rotating the tires. thats free. if the car pulls the other way, then you may have a tire problem.
Old Oct 5, 2003 | 01:54 AM
AspectIndustries's Avatar
Default Re: car pulling to the right (Sukebei Oni)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sukebei Oni &raquo;</TD></TR><TR><TD CLASS="quote">
no. could be a tire pull. or even a brake problem. try rotating the tires. thats free. if the car pulls the other way, then you may have a tire problem.</TD></TR></TABLE>
True. It can be couple factors.
Tires -like IH8RICER said, switch ur front two tires around...See if it still does the same thing.. if it still turns to the right still, then i would say its alignment.
Old Oct 5, 2003 | 05:25 AM
ggangtong81's Avatar
tire pressure can be a factor too. if right tire has a less pressure, it will tilt to right.
Old Oct 5, 2003 | 05:49 AM
Arsenal's Avatar
Default Re: car pulling to the right (ggangtong81)
How about a steering rack, my car also pulls to the right, but very hard, when the car is in the air, and wheels of the ground, I can move my wheel, I assume its the steering rack?
Old Oct 5, 2003 | 11:38 AM
Default Re: car pulling to the right (Arsenal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arsenal &raquo;</TD></TR><TR><TD CLASS="quote">How about a steering rack, my car also pulls to the right, but very hard, when the car is in the air, and wheels of the ground, I can move my wheel, I assume its the steering rack?</TD></TR></TABLE>
Some hardcore racing in air.
Old Oct 5, 2003 | 11:55 AM
Default Re: car pulling to the right (synik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by synik &raquo;</TD></TR><TR><TD CLASS="quote">
Tires -like IH8RICER said, switch ur front two tires around...See if it still does the same thing.. if it still turns to the right still, then i would say its alignment.</TD></TR></TABLE>
IH8RICER didn't say that, i did
Old Oct 5, 2003 | 11:57 AM
alfaaay's Avatar
I'd try everything that everyone has suggested before getting an alignment. Is your car lowered? If it is, then out of whack toe angles are at least some of the problem.
Old Oct 5, 2003 | 12:00 PM
RedLinin247
Guest
Posts: n/a
Default Re: car pulling to the right (alfaaay)
alignment.
Old Oct 5, 2003 | 01:56 PM
patdemps's Avatar
Default Re: car pulling to the right (RedLinin247)
It could be a variety of things. If you have a tire pressure gauge, then check your tire pressure. I'd get an alignment next and see if that fixes the problem. If it does then there ya go. I'd say the alignment is probably the most obvious thing your looking at. But who knows.
Old Oct 5, 2003 | 02:00 PM
Newman's Avatar
New User
Default Re: car pulling to the right (patdemps)
put your steering wheel straight and look at your wheels. They're most likely toe out from the car (which occurs when you lower the car). It's actually pretty easy to do the toe adjustment in your driveway with a tape measure and a cresant wrench and takes less than 5 min. You just need to see how much toe your car has adjust the tie rods accordingly. Had to do it to my DA Integra when I put some Teins on it.... car pulled to the right before I fixed the alignment. Now it drives fine and nice & straight and doesn't pull. The wheels are also straight now, aligned with the body so there is no more toe out.
Old Oct 5, 2003 | 04:54 PM
sickintegra4u2nv's Avatar
check tire pressure tire size, could be alightment could me the pressure could be tire wear....it can also be a siezed caliper a bad tie rod..it can many many things
vinuneuro
33
Jul 26, 2008 08:44 AM
MEDIEVIL
Oct 11, 2006 04:57 PM
G2_Fella
Oct 6, 2006 05:27 PM
parki59
Apr 25, 2006 03:37 PM
Jaydeep
Sep 15, 2004 11:56 AM
