Car over heating
Old Apr 24, 2005 | 08:04 PM
J-g-D-s-M-r's Avatar
Default Car over heating
hey, so my car is over heating as the topic stated. i have replaced the radiator and bought new hoses. so i start the car and let it idel for about 10 mins. warms up just fine, take it for a test run and seems ok, but when i pop vtec it starts going over. it gets hot and eventually crosses the "H" on the temp guage. luckly i was only a few houses from my house. i know it's not the temp sensor b/c i can smell coolant burning. where might this leak be? some friends say i might have to change all the gasket on my engine. i want to be sure before i do so.
Old Apr 24, 2005 | 08:08 PM
4U2NV's Avatar
Default Re: Car over heating (J-g-D-s-M-r)
How many times has it "eventually" crossed the "H"...? It's not good for it to get there even once, but anyhow... I'd check all visual things in the engine bay... Check all hose connections, check radiator and over-flow level... Check for and oil/coolant mixture in both the overflow and under the valve cover... Does the car smoke...? If so, what color is the smoke, etc...? Do the fans come on...?
XSIWANNAB's Avatar
i just got done changing my radiator,did u fasten all the hoses and clamps,that might be why ur smelling coolant.are your fans plugged in.did u use same hoses???if u did u might hav a leak.what about the bottom of the radiator did u fasten the inlets?????
Old Apr 24, 2005 | 08:12 PM
Danziver's Avatar
Check your fans.
Old Apr 24, 2005 | 09:03 PM
Slain's Avatar
check your thermostat
Old Apr 24, 2005 | 09:20 PM
DavidT or VajT's Avatar
Default Re: (Slain)
LOL, another blown head-gasket.
Old Apr 25, 2005 | 01:46 AM
Default Re: (DavidT or VajT)
yea hoses are brand new from the dealer and clamps are on. no smoke is coming out. i dont see any coolant / oil mixture so i'll go with the blown head gasket. i'll change that first and see from there. thanks for the help.
Old Apr 27, 2005 | 12:36 AM
derrick2237's Avatar
Default Re: (J-g-D-s-M-r)
Chu-Head, any luck with changing the thermostat?
R_A_Y_N_E
Jan 8, 2015 04:18 PM
eli_said
Oct 1, 2012 05:20 AM
zbra09
Dec 19, 2009 08:30 AM
GSR_Jamee
Feb 3, 2005 07:48 PM
lost_sol
Jan 24, 2004 02:33 AM
