car heating up with A/C on...?
Old Aug 9, 2001 | 03:22 AM
Answer's Avatar
Default car heating up with A/C on...?
on city driving, my car is heating when I have the A/C on... when I stop the A/C, everything goes back to normal... what could cause this?
Old Aug 9, 2001 | 04:06 AM
DavidGSR's Avatar
Default Re: car heating up with A/C on...? (Answer)
It is possible one of the cooling fans isn't working. There are 2. One comes on when the A/C is running. To check this, get the car up to normal temperature (or if it is running hot) and see if both fans are on. If one isn't, that is your problem. If they are both working, I would think radiator (possibly) or thermostat(doubtful).
Old Aug 9, 2001 | 06:25 AM
TypeC's Avatar
Default Re: car heating up with A/C on...? (DavidGSR)
my car was doing that last month. It turned out that the cooling fan fuse (under the hood) was blown. replaced it and it works fine now (always stays at about 10 o'clock regardless). -C
Old Aug 9, 2001 | 07:21 AM
Answer's Avatar
Default Re: car heating up with A/C on...? (TypeC)
well, I checked the fans this morning and I never saw the engine fan run, and the A/C fan did run when I put the A/C on, but after 5-10 mins, she was stopped... where is the fuse for the cooling fan??
Old Aug 9, 2001 | 10:21 AM
TypeC's Avatar
it's in the main engine fuse box located at the top left of your engine compartment (when facing the motor). It's a 15A fuse if I remember correclty (or was it 10A). hth, -C
JerseyJohnny
Sep 2, 2015 04:00 PM
VIDC2
Aug 24, 2010 08:24 AM
CRIMEIII
Mar 20, 2008 05:39 PM
Jammersplace
Jan 20, 2007 05:38 PM
