Radiator Fan Problems
this is what happen.
1) fuse blew to the fan and the ac/fan inside the car.
2) replaced the fuse
3) nothing happened.
so i needed to know if there is a relay or something that may need to be changed cause i did the multimeter thing and the 3-4 fuses in a row NO POWER to all of them even when the car is running. i can't go driving around without the radiator fan running thats just asking for problems. Anyone PLS gimme a good idea its setting up and the motor was just rebuilt/resleeved new pistons and rods the whole nine. now im scared to run it
Re: Radiator Fan Problems (Jammersplace)
when you put a new fuse in did it pop?
do you know where the fan switch is?
jump the pins on the plug and see what happens..
and check the fuse before and after this!
Re: Radiator Fan Problems (gezzuzz)
ok the fuse didn't pop its doing good but im getting no power using a volt meter to the slot the fuse goes into or even the whole row that the section is on. ill post a pic and highlight what is out it might be the actual fuse block
Re: (EKHWhat)
in the fuse slots one of the connections i think its the bottom one alway has power most of the other slot have power even ones im not using they should have power.
the rest of them do except the ones that use the acc switch on the ignition
LonelyDriver02
08-14-2004 03:41 PM
