car has starting problem
Old Feb 6, 2005 | 02:51 PM
rough_draft's Avatar
Default car has starting problem
I'll push the clutch in and usually the car will start but sometomes it just wont turn over. I will have to really push down hard on my clutch and then it will fire right up. I know when i push my clutch down it completes a circuit and i believe that there is a problem with the connection or a switch when i depress the clutch. Is there anyway i can fix this switch or just get rid of it all together? I"m not dumb enough to start the car while its in gear. Thanks guys
Old Feb 8, 2005 | 04:24 PM
go250mph's Avatar
Replace the clutch safety switch at the top of the cluch pedal.Or just disconnect it and attach the 2 wires together.This will also make the car start while in gear with the clutch pedal not pressed down.
Nataku
Oct 19, 2007 11:39 AM
Honduh Uhcord
Oct 14, 2007 02:33 PM
napalm_srv
Jan 2, 2005 11:26 PM
deviant1
May 7, 2003 11:26 AM
o.G.A.g.
Aug 18, 2002 03:12 PM
