ABS help!
does not belong there.
it belongs under the back seat. the rear wheel sensor on each side will plug to it. i would say the longer one belongs on the left side and the shorter one belomg on the right side.
does your car has the sensor? if not it should throw a abs light. rear wheel sensor, infinite
1 Post
Re: (esponet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esponet »</TD></TR><TR><TD CLASS="quote">does not belong there.
does your car has the sensor? if not it should throw a abs light. rear wheel sensor, infinite </TD></TR></TABLE>
whoa................thats what code my 94 gsr is throwing. Front passenger wheel speed sensor.......need to find out whats wrong with mine........
Re: (iH8RICERZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ »</TD></TR><TR><TD CLASS="quote">
whoa................thats what code my 94 gsr is throwing. Front passenger wheel speed sensor.......need to find out whats wrong with mine........</TD></TR></TABLE>
Better hope that you dont need a new one. Thats not a cheap part, I found that out that hard way.
you see that small piece of metal covering some wire. unscrew that if you have the sensors it should be undrnesth there.
but being that those wires were in the wrong place, i' guessing you don't have those sensors. it would be weird and something is wrong, if you don't have a abs light on
Re: (esponet)
which metal piece are you talking about? i actually had my car repainted to black and they forgot how the abs wiring hooked up. so im trying to figure it out but i cant seem to find the other end that connects to those two wires.
Re: (Jj0o3eyY)
My guess, for you & liquid both...
That wire loom is actually supposed to go across the car. Not up along the fender, but down near the base of the back seat. How about undereath that stamped metal shroud you can see...
I think the upper circle is for the right rear wheel, the lower one for the left. The wires for the wheel sensors come thru holes in the body somewhere, that's where the orange plugs need to be.
