Car is cutting power
I have a 1994 Acura integra ls. It’s a circle track race car. My car will cut all acceleration near redline at random times. I will have no throttle response until I go below 3500 rpm then I get it back until 3500 and it will cut off again. If I wait longer say 5-10 seconds after it occurs it will give me full redline of power again but will quickly shut off again not long after. I have made sure my full pump is in good working order. New dizzy, new spark plugs. Not sure what it is. It’s also tough to test because I can only drive the car at the track. Anything will help, thank you
Re: Car is cutting power
could be oil related, it's not a vtec engine but how's the oil levels?
What ECU? any codes pop up?
Check the TPS sensor and make sure its within spec.
