Car bogs while driving
Old May 26, 2014 | 03:29 AM
slow_low_eddie's Avatar
Default Car bogs while driving
Just converted my car to obd1 since it has been running with the stock obd0 ECU.
Anyway, a friend of mine has the same set up as me, b18a1 with PR3 pistons, only differences are our tranny's and he has injectors. I plug my ECU into his car and runs fine.
On my car however, she idles great but runs like crap. Bogs most of the time. I'm thinking injectors may be the problem? Would anyone happen to know? The ECU is a chipped p06.
Old May 26, 2014 | 08:34 AM
tamboo's Avatar
10 Year Member
Default Re: Car bogs while driving
do cams/crank line up properly?
tested tps?
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/official-honda-tps-wiring-calibration-thread-2830131/
Old May 31, 2014 | 03:00 PM
Originally Posted by tamboo
do cams/crank line up properly? tested tps? https://honda-tech.com/forums/showthread.php?t=2830131
I actually just changed the cam seals and I'm sure the cams/crank line up properly. At least my mechanic didn't tell me anything. He even tightened my timing belt a bit since it was a bit loose. Also, I calibrated my tps a few months ago and it was dead on. Should I check again?
Now that I think, my buddy does have a fuel pressure regular, aem fuel rail and the accel injectors.
Old Jun 1, 2014 | 04:38 AM
tamboo's Avatar
10 Year Member
all mechanics are not created equal.
pull valve cover and eyeball cam alignment plz.
see pg 6-12:
http://www.spooledupracing.com/downl...als/FSM/Honda/
i also got intermittent bogging when fuel pump and icm were on the way out.
Joacnel
Jul 6, 2015 12:04 PM
vtechachey
Feb 5, 2008 06:26 PM
APEX CRX
Sep 19, 2006 10:59 PM
handa
Feb 22, 2006 07:01 PM
