Car bogging problems
Old Mar 15, 2005 | 07:51 PM
jdmeng's Avatar
Default Car bogging problems
Hey guys I just needed your guys input. I've been working on my gf's 94 integra gsr. The car has some massive bogging when accelerating. I just got done replacing the spark plugs with some ngk's, ngk spark plug wires, and a new oem cap and rotor. I'm still getting the same bogging. I checked the spark plugs and i noticed they were ashey white on the tip and also theres oil on the spark plugs. Any input guys? i'm not no pro mechanic or anything. I'm just guessing theres a leak in the valve cover gasket (the rubber ring gasket) and the cars running lean since the spark plug tips are white. Any inputs will help me thanks.
Old Mar 15, 2005 | 08:33 PM
the DA in HONDA's Avatar
Default Re: Car bogging problems (yOo_JeAn)
injectors might be dirty, just a thought
Old Mar 15, 2005 | 10:13 PM
Ri5e's Avatar
how are the plugs gapped?
check your o2 sensor
Old Mar 17, 2005 | 12:54 AM
jdmeng's Avatar
I was thinking the injectors are dirty too. The plugs are gapped to stock specs on a bkr7e-11 ngk plugs.
Old Mar 17, 2005 | 01:05 AM
Dc2 Powered's Avatar
my friedn told meit could be somthing behind the intake manifold buti was kinda drunk when he told me so i have no idea what its called but its like 80 to replace?
dont mean to thread jack but my car bogs sometimes when i push it.. it'd be normal then when i push it at the next stop it will bog andsometimes even die
Old Mar 17, 2005 | 10:27 AM
blk_db2's Avatar
Default Re: (Dc2 Powered)
try using a warmer plug..... your shouldn't need bkr7e-11 unless your at >12:1 compression... use bkr6e-11 and check your timing...
Old Mar 17, 2005 | 10:50 AM
4.6LJeepXJ's Avatar
Default Re: (blk_db2)
He was probably talking about your throttle position sensor (TPS). if you prob the signal wire coming from the TPS it should be .5V at idle 10% and 4.5V at WOT close to 100%. From there check injector duty cycles and pulse widths with a noid light. If the info coming from the ECU is good the pulses should be within spec (sorry I dont know the spec for your teg). If you dont see something off here, and you have DTCs stored then your injectors are probably Dirt McGurt.
The heat rating on plugs is the rate at which the plug can dissapate heat. So long as you arent under the rating you are all set.
And also as stated above Check your o2 for switching..high and low.
Old Mar 21, 2005 | 05:36 AM
jdmeng's Avatar
how do i check the timing? sorry i'm a newb
Old Mar 21, 2005 | 06:47 AM
P73typeR's Avatar
u need a timing gun...
Old Mar 21, 2005 | 06:49 AM
P73typeR's Avatar
u took off the distributor to switch the cap and rotor...did u mark the distributor to make sure u put it back in the right spot? try to retard the timing all the way and see how that goes...
Old Mar 21, 2005 | 03:18 PM
jdmeng's Avatar
yeah I put the wires back in the right order.
Old Mar 21, 2005 | 10:03 PM
P73typeR's Avatar
right but is the distributor back on the same spot it was before? did u mark it? if not u probably just put it on and threw the timing off..loosen the bolts and retard the timing...
Old Mar 23, 2005 | 09:28 PM
jdmeng's Avatar
im sorry but I dont know what "retard" the timing is. When I tried to replace the rotor, I had to spin the rotor untill the bolt holding the rotor lined up so I can unbolt it. So when I replaced the rotor it should of been the same as before?
Old Mar 23, 2005 | 09:29 PM
jdmeng's Avatar
but then again, the car bogging was still there before. I should research more about the timing. People are telling me to retard or advance the timing but I have no clue wth that is. haha
Old Mar 24, 2005 | 04:46 AM
thegamemeng's Avatar
Default Re: (yOo_JeAn)
as said above, check the injectors/spark plugs
Old Mar 24, 2005 | 05:35 AM
JamaicanDM's Avatar
Default Re: (thegamemeng)
yea definately check all the ignition parts first
Old Mar 24, 2005 | 05:44 AM
Backk InTheDA's Avatar
I hate everything
An easy way to test your injectors is, take a long screwdrive, touch the metal end down to one injector, then put your ear directly on to the handle of the screwdrive. If it's not making a clicking noise, your injector is bad, do this with all four of them.
But, this will only tell you if there bad, not dirty unfortunetly.
Good luck
iTR
Old Mar 24, 2005 | 08:26 AM
P73typeR's Avatar
u sure u put all the spark plug wires back in right order?
Old Mar 24, 2005 | 11:43 AM
supercharged18g's Avatar
i would definitly check the timing
Old Mar 24, 2005 | 01:01 PM
94twinv-tec's Avatar
Hey bro.. I ran to the same problem with my GSR and I found that when you take out the spark plugs, use something clean and go inside where the spark plugs are and clean the inside. It's the oil that is leaking into where the spark plugs are. It's bogging because the sparks ain't coming good. Try it ...I guarantee it'll work.
Old Mar 24, 2005 | 01:19 PM
vidanator's Avatar
Default Re: Car bogging problems (94twinv-tec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94twinv-tec &raquo;</TD></TR><TR><TD CLASS="quote">Hey bro.. I ran to the same problem with my GSR and I found that when you take out the spark plugs, use something clean and go inside where the spark plugs are and clean the inside. It's the oil that is leaking into where the spark plugs are. It's bogging because the sparks ain't coming good. Try it ...I guarantee it'll work. </TD></TR></TABLE>
what exactly did u use, just a shop towel? did u spray anything also?
Old Mar 24, 2005 | 09:12 PM
norcal69's Avatar
my 91 rss with a b20b has the same problem it is at iidle say i idle down the street the go wide open the car boggs out it that what you car does ???
Old Mar 25, 2005 | 10:23 AM
jdmeng's Avatar
when I try to accelerate with very light throttle the car doesnt bog. But when I try to use a lil more throttle the car just bogs like a ******. I'm going to try to clean out the oil and replace my valve cover gaskets to hopefully stop the oil leaks, then replace the fuel filter.
Old Mar 25, 2005 | 10:33 AM
norcal69's Avatar
dude thats what mine does. i changed the fuel filter and it still does that. i cant figure it out. i'm taken it to my friends shop today and i'll tell you whats up when he finds out. cuz sounds like we have same problem .
Old Mar 25, 2005 | 10:37 AM
norcal69's Avatar
Default Re: Car bogging problems (norcal69)
my first post i sond retarded look at the words i try to type to fast lol...... when your at idle does you idel jump from 800-1300 rpms????
