can't get reverse
Old Jan 10, 2004 | 12:29 PM
fasterthanU's Avatar
Default can't get reverse
i cant get my gsr into reverse. all other gears are fine i just cant get reverse. the temperature is 20 degrees and i'm hoping thats just it i've since pulled it in the garage and am letting it warm up but even after driving it for 15min it still won't go into reverse
Old Jan 10, 2004 | 12:40 PM
obsidianG35's Avatar
Default Re: can't get reverse (fasterthanU)
some details would help..
stock clutch or aftermarket?
how many miles on current clutch?
Old Jan 10, 2004 | 12:55 PM
Default Re: can't get reverse (r4integra)
origanal stock clutch 110000 miles amsoil gear lube
Old Jan 10, 2004 | 01:20 PM
kinda rare that reverse goes out first but I'd say clutch is the most obvious. good luck
Old Jan 10, 2004 | 02:07 PM
Team 4R's Avatar
i know two guys that are having the same problem now..... one is an ex tranny and one is an si tranny.... i had the same problem a little while ago on an si tranny after a romp at the drag strip..... my issue fixed itself during a five-hour freeway run, so give it a little time and see what happens.....
Old Jan 10, 2004 | 02:50 PM
FlaN.'s Avatar
most likely the clutch as stated above. did u drive it for 15 minutes, or did you let it warm up for 15 minutes?
SiRkid
11
May 19, 2006 01:55 AM
mawkiemarc
Aug 1, 2005 08:41 PM
J-Brooks
Dec 17, 2002 10:23 AM
phatintegra
Mar 21, 2002 08:46 AM
civic_sir94
Nov 27, 2001 05:45 AM
