Can't fully tighten rear strut from the top
I recently came across blox lowering springs and the install went smoothly in the front on my 95 gsr, when it came to the rear I broke both Bolts on the lower control arm ha to buy new control arms and a new struts because I didn't feel like dealing with the broken bolt, so I bought stock rear struts from acura along with lower control arm bolt that goes into the shock, I bought a nice pair of rear lower control arms from skunk, now everything is installed nice and dandy and when I took the car off the jack stands I noticed in the rear trunk that the strut nut is out of thread and I can't tighten it anymore and there's still about half an inch of space from the nut and the bushing, I did not forgot any bushings it is done properly, what should I do ?through another bushing ontop so I can fully tighten the strut? Or would that be an issue. Has anyone ever run into an issue with installing lowering springs on stock struts besides blowing the strut prematurely,
