Cant check engine light code
Old Aug 31, 2007 | 02:44 PM
f22c's Avatar
Default Cant check engine light code
I ground the wire and everything but the light does not blink. It stays lit. How else can I check the light code.
And Sometimes my car wont start 1992 Integra RS. Sometimes I start it and it bogs out and dies then wont start for awhile then starts up fine. No clue whats wrong Just bought the car a few weeks ago.
Any help would be greatly appreciated. Thank you.
Old Aug 31, 2007 | 03:34 PM
1Point8DC2's Avatar
Default Re: Cant check engine light code (f22c)
don't ground anything jump the two wires together with a paperclip or small piece of wire
Old Aug 31, 2007 | 06:05 PM
mn_babyboy's Avatar
Default Re: Cant check engine light code (1Point8DC2)
My cuz is having the same problem, we try everything to see what check light is on. But it wont show either. He's going to change a whole new block too see if thats causing any problem. He is having the same issue.. I'll let you know when he fix it.
Old Sep 5, 2007 | 02:22 AM
f22c's Avatar
I did that and everything but it dont work. I have no clue why it dont or anything. Heres some more info that might help...Umm Somtimes I can drive for like a long time before the light even comes on. and sometimes it comes on after I drive down the road. Dunno if that helps.
Thanks mn_ would appreciate that.
Old Sep 5, 2007 | 02:57 AM
Haleiwa-Brando's Avatar
Paper clip trick, as said before. If the paper clip is not working, pull the positive lead off the battery for a few minutes. This will reset the ECU. Drive the car normal. When the check engine light comes on again, turn the car off. Next take the paper clip and put it in the two-wired female harness. Turn the key to II and watch the check engine light. Use a paper and pen to write down the sequence.
blaze.1
Sep 24, 2009 11:04 AM
ryanminer
Oct 17, 2008 08:52 AM
ANONYMOUSdeecee
Dec 28, 2006 08:00 PM
Bictorious
Feb 19, 2004 03:59 PM
wadafa
11
Oct 3, 2002 03:49 PM
