Can I Replace This Bushing? (Pic Inside)
Old Sep 2, 2003 | 05:12 AM
808style's Avatar
Default Can I Replace This Bushing? (Pic Inside)
is it possible to just replace this bushing or do i have to replace the entire outer tierod?
Old Sep 2, 2003 | 05:41 AM
Dee's Avatar
Dee
Default Re: Can I Replace This Bushing? (808style)
Try replacing just the boot first!!
Old Sep 2, 2003 | 05:45 AM
808style's Avatar
Default Re: Can I Replace This Bushing? (Dee)
oh so that rubber thing thats all cracked and flattened is just a boot that i can replace? all i know is it looks like *** and my suspension creaks like mad!
Old Sep 2, 2003 | 07:19 PM
Brian_TII's Avatar
Yes, it's just a boot, and it's less than $10 for the part from the dealership. The only thing that sucks about it is that you have to get the ball joint out of the lower control arm / steering knuckle. If it is already making noise.. it might be too late... and you would need to replace the end link (about ~$60 for a new end link + alignment)
Old Sep 2, 2003 | 08:52 PM
.xcalibur.'s Avatar
Its possible to replace the bushing. THe labor shouldnt take long either. I do have some brand new tie rod and control arm bushings for the integra. They are Energy suspension. Let me know. I will sell all 3 pairs for 12 shipped.
Old Sep 2, 2003 | 09:26 PM
Cyphear's Avatar
Mine has a crack in the rubber (it looks like yours does too). I just packed as much grease as possible in there and haven't had any problems since. It's been about 5,000 miles. Then again $12 isn't bad. Just make sure u dont have to have anything machine worked, i heard that you have to have those pressed, but i don't really know, it does seem like that rubber boot is attached to that tie rod though... Good luck.
Old Sep 2, 2003 | 09:40 PM
.xcalibur.'s Avatar
Default Re: Can I Replace This Bushing? (Cyphear)
the rubber boot comes off in about 2 seconds. just need a ball joint puller. you can rent one at autozone for free.
Old Sep 2, 2003 | 09:49 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
It's not a bushing, it's a balljoint w/ outer boot to hold in the grease. If it's making noise you probably need to replace the balljoint, and the tie rod end with it.
And polyurethane balljoint boots are useless, you don't gain anything from it, and they actually let the grease leak out easier than a regular OEM rubber boot.
Old Sep 2, 2003 | 11:18 PM
Cyphear's Avatar
Default Re: Can I Replace This Bushing? (.xcalibur.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .xcalibur. &raquo;</TD></TR><TR><TD CLASS="quote">the rubber boot comes off in about 2 seconds. just need a ball joint puller. you can rent one at autozone for free.</TD></TR></TABLE>
Right. I'm just saying i think the rubber boot is attached (pressed into) to the upper part (control arm/tie rod). Let me know if i'm wrong though, i seem to be going against the majority.
Old Sep 3, 2003 | 05:16 AM
808style's Avatar
so i should just go to the dealership and ask for a dust boot for a tierod endlink? should i just try and grease it up or replace the entire endlink? yea it does creak, but if all it needs is some grease and a new dustboot, i'm taking the cheap way out. i hope its as easy to install as some people are saying...
Old Sep 3, 2003 | 08:41 AM
Rpc07's Avatar
Default Re: Can I Replace This Bushing? (PatrickGSR94)
[QUOTE=PatrickGSR94]It's not a bushing, it's a balljoint w/ outer boot to hold in the grease. If it's making noise you probably need to replace the balljoint, and the tie rod end with it.
QUOTE]
what he said... i had the same problem and i had to replace the hwole tie rod because you cant just get the bushing seperate. it was like $40 at the dealership but thats with my 30% discount i get. so it might be a little more.
Ryan
Old Sep 3, 2003 | 05:53 PM
toyotaturbo's Avatar
No, they aren't attached. I just did some Energy Suspension tie rod end bushings on my Integra. They come off very simply, and are easily replaced.
Old Sep 4, 2003 | 10:52 PM
pineapplemike's Avatar
mine has been broken for a long time. probably like a year and 12,000 miles. i've been very lazy to change it out and i didn't think paying a mechanic like $100+ was worth it. i haven't noticed anything bad, but i know i should fix it.
Old Sep 5, 2003 | 03:52 AM
len's Avatar
len
You'll need items 14 and 15. Make sure you put grease back in and replace cotter pin, item 25.
Old Apr 1, 2006 | 08:24 AM
fishdogg's Avatar
Default Re: Can I Replace This Bushing? (len)
Gold DA9
Apr 7, 2011 09:24 AM
arielb1
Oct 31, 2008 12:29 PM
jwbnavy
12
Nov 28, 2007 06:36 AM
Jagan'92
Feb 24, 2004 06:19 AM
blackEF
Jun 27, 2002 09:23 AM
