camshaft difference
Old Jun 3, 2003 | 07:10 AM
dtyst's Avatar
Default camshaft difference
I wanted to know if any one knew the differences between using ITR cams over CTR cams in a gsr? which would be more reliable and produce the most power? bottom line which is better ???should i also replace springs and retainers ?
98 gsr
Old Jun 3, 2003 | 07:37 AM
P1mpSlap's Avatar
They are about the same.
01 ITR cams are about the same as the newer CTR cams. The lift and duration might be slightly to the advantage of the CTR. Yes, it's recommended that you replace the springs and retainers. At least move the GSR Intake springs to the exhaust side, and replace all of the intake side.
Old Jun 3, 2003 | 08:39 AM
zad5's Avatar
Default Re: (P1mpSlap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">
00-01 itr intake cam are exactly the same as ctr. all the others itr cams intake cam duration are 3 degree's less than ctr.
aznsins88
Jan 1, 2005 07:19 PM
JDMlyfestyle
Nov 1, 2003 06:26 PM
thrty8street
Oct 27, 2003 07:44 AM
madhatch
Jun 23, 2003 10:37 AM
PnX-R
Apr 25, 2002 09:28 PM
