Cams and Compression?
Old Feb 3, 2003 | 09:20 PM
Slipped_Away03's Avatar
Default Cams and Compression?
I am building a 94 B18c1 GSR motor I am looking to run a 11.4:1 CR. What do I have to do to achieve this. So far I got SKunk2 High Compression valves that are rumored to raise CR .3-.5 points. I will also be using eagle rods and here is where im stuck. I know Honda pistons wont work on these rods so can you please recommend a set that will, I would like them to be 11:1 pistons.
Second- Will a SKunk2 Stage 2 cam make good power at this CR range
Thanks
Old Feb 3, 2003 | 10:33 PM
IN VTEC's Avatar
Default Re: Cams and Compression? (Slipped_Away03)
I think you'd better double check on the flat faced valves. .3 to .5 seems like it's way too much for such a small change in volume.
Dunk them in a .1mL precision graduated cylinder in the chemistry or biology lab to measure the change in volume...but this only works if the valves are the same size....no oversized vs. stock measurements.
BTW, go higher than that on compression. Make it a nice, fun, expensive building experience.
I'm not big on aftermarket pistons yet, but check out http://www.importbuilders.com for a listing of the pistons they like to use.
[Modified by IN VTEC, 1:35 AM 2/4/2003]
Bleez
Nov 15, 2011 06:35 PM
noracelimit
Mar 30, 2009 12:21 PM
tegra2G
11
Oct 26, 2008 04:37 AM
7mile
Feb 6, 2006 09:08 PM
