cams?????
Old Mar 3, 2002 | 05:42 AM
FlipboiGSR's Avatar
New User
Default cams?????
what i really want is some JUN cams but they're hella expensive. does any 1 know where to get cheap reasonable prices for them. and what other choices of cams should look into other than skunk2, jun & crower. i did a search already, but not good results
thanx
Old Mar 3, 2002 | 06:54 AM
TRuST's Avatar
Default Re: cams????? (FlipboiGSR)
If money is an issue, then ITR cams are best bang for the buck. But if you think you can spend a little more the Skunk2 stage 1 should fit you fine.
Old Mar 3, 2002 | 08:13 AM
98SILVERGSR's Avatar
From: I want a 3some with Chasey Lane and Jenna Jameson, Canada
Take a look at the Toda spec A's here:
https://honda-tech.com/zerothread?id=133308
And the best part is, all they need is ITR valve springs (which since you have a GSR you'll only need the intake side and move your GSR intake springs and stick them onto your exhaust ) if you keep them at ITR's redline. So relatively cheap setup, and I found the spec A's for a difference of about $300 over the ITR's; well worth it IMO from what I've seen/heard of the Spec A's and you can get at least 5-10 hp more over the ITR's with them in.
[Modified by 98SILVERGSR, 11:41 AM 3/3/2002]
Old Mar 3, 2002 | 09:38 AM
Type S's Avatar
get the skunk2 stage II cams. check http://www.jdmhondaparts.com for them i think they are $750 for any of the 3 stages. with these cams you are going to need stiffer valve springs and ti retainers. you cold go with the skunk2 dual valve springs, and ti retainers. And to take advantage of these cams you are going to need to raise your compression (JDM ITR pistions with a spoon head gasket or spoon ballanced ITr pistions with a spoon head gasket). I think the spoon ballanced pistions are oversized and your block will need to be honed. Also you will need to raise your redline cause cams with high lift and duration make power around 9000-9500 RPM.
With aggressive cams lots of things have to be taken into consideration, do your research on this board and you will make the right choice for your budget
Old Mar 3, 2002 | 12:01 PM
alexboy's Avatar
if you can't afford the Jun cams get the skunk2's . The stage 2's compared almost equally to the Jun 3's and for about 3000 less. If you cant afford them buy some used itr cams for about 350- 450
Old Mar 3, 2002 | 12:06 PM
GokuSSJ4's Avatar
Default Re: cams????? (alexboy)
skunk stage 2 ,and youll create some good #'s
Old Mar 3, 2002 | 02:04 PM
GSR_Hacker's Avatar
New User
Jun are good, but so are Toda and Skunk2... Whatever you do... DON"T BUY A CROWER VALVETRAIN PRODUCT. I have seen several of their cams snap into pieces... I now also get to expierence in the Crower Carnage with my own expirence with their crappy products... See pics of Crower's work on my motor...
http://www.tamparacing.com/hebb/show...threadid=19543
I think a good set of Todas would be a fun setup...
Junior_7
Jun 6, 2005 09:41 AM
jdmcx
Jan 5, 2004 06:58 AM
skellator_thoj
14
Oct 4, 2002 04:42 PM
yellowbuffalo
Feb 12, 2002 06:42 PM
