Calling anyone that has removed a tranny from a teg.
I am currently in the process of doing a lot of work on my teg. The main thing right now is putting a new clutch in. I have the service manual and a Haynes manual, but I still have a problem. I cannot get the left (driver side) axel and intermediate shaft out of the tranny. I got the one on the right out with no problem, but the left one is so stubborn. I have tried everything the manual says, but no luck.
Has anyone had this problem? How did you get it out? Any hints or tricks? Thanks in advance.
Re: Calling anyone that has removed a tranny from a teg. (m3ster)
the only thing that gave me trouble when removing all that **** was the sway bar... the car had to be perfectly level and ****... or somethin would push on the another... but... sounds like u have other problems
Re: Calling anyone that has removed a tranny from a teg. (LSTEG96)
hmm,just to get the basis down, you took off the left wheel right? the lest side is definately a bitch...
Re: Calling anyone that has removed a tranny from a teg. (JunIntegra)
The axle is locked with a clip, the intermediate shaft just slides out (after your remove the bolts). Pry bar works wonders: tap it in with a hammer, turn the axle 90 degrees, tap some more and keep working your way around until it comes out.
Re: Calling anyone that has removed a tranny from a teg. (PupaScoopa)
I agree with pupascoopa, just remove the three bolts attaching the intermediate shaft and use a pry-bar, or you could remove the axle/intermediate shaft from the hub and drop the whole thing out all at once and remove it then.
soysauce90CRXsi
09-10-2008 09:15 AM
maxheat
51
01-08-2005 09:49 PM
