A/C troubleshooting
Old Jun 29, 2006 | 10:09 PM
Maireeka's Avatar
Default A/C troubleshooting
I'm trying to fix my AC right now, and I need a little help finding the problem out. I have had the freon pressure checked, the guy said it was alright. The problem is that the compressor will not kick on.
I checked to see if power was getting to the compressor using my multimeter, and it appears that when I have the AC on high there is no voltage running through the compressor's power wire.
Where should I go from here? Is there a fuse for the AC circuit I need to check? If there is, which one is it? the fuse panel cover in my car is gone so I don't have the little map that tells me which fuse is which. If a fuse is not the culprit, I might get a second opinion on the freon pressure, because after I searched, I found out that if pressure is under 25psi then the compressor won't kick on.
Old Jun 30, 2006 | 06:57 AM
Maireeka's Avatar
Default Re: A/C troubleshooting (Maireeka)
any ideas? anyplace I can look about AC repair in my DA?
Old Jun 30, 2006 | 11:19 AM
subgeniusdude's Avatar
What about the A/C relay ? Try running a wire from the + post of your battery directly to the compressor,just dont keep in on there too long,the compressor is designed to cycle on and off.If it works theres probably a problem in your wiring somewhere.Do continuity checks,they are your friend as well.Good luck!
pro1911
Jun 29, 2024 09:52 AM
saikou
Aug 9, 2011 08:22 PM
superfuji57
Jul 14, 2007 05:38 PM
dc2jdmteg05
Jul 20, 2005 12:37 PM
Johnnytech
Aug 21, 2004 05:25 PM
