a/c system
Old May 27, 2003 | 03:33 PM
Brian-Brian
Guest
Posts: n/a
Default a/c system
refilled my freon last month... was running real cold and now it's just blowing regular air and sign of leaks or anything cuz the mechanic put some grn dye can someone tell me what else can it be thanks
Old May 27, 2003 | 03:34 PM
AWDxBOOST's Avatar
Default Re: a/c system (Spoon_b18)
compressor problems most likely
Old May 27, 2003 | 03:56 PM
Brian-Brian
Guest
Posts: n/a
Default Re: a/c system (ls_teg)
do u know avg price for a compressor 96 GSR
150-200?
Old May 28, 2003 | 06:08 AM
JimBlake's Avatar
Compressors usually make noise if they're bad?
What about a leak at the evaporator core or the expansion valve. You gotta take apart the ventilation distribution box (inside the dashboard) in order to see the dye if its leaking from any of that stuff.
Old May 30, 2003 | 11:26 AM
AWDxBOOST's Avatar
Default Re: a/c system (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Compressors usually make noise if they're bad?
What about a leak at the evaporator core or the expansion valve. You gotta take apart the ventilation distribution box (inside the dashboard) in order to see the dye if its leaking from any of that stuff.</TD></TR></TABLE>
he didnt anything about noise...but you might be right. check what he says before you get it to a shop
Old May 30, 2003 | 01:55 PM
non-VTEC's Avatar
take it back to the shop that filled it with the r134a dye and they should be able to check for leaks with the black light.
good luck
Old May 30, 2003 | 02:52 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls_teg &raquo;</TD></TR><TR><TD CLASS="quote">he didnt [say] anything about noise...</TD></TR></TABLE>
Well, yeah, that's exactly what I meant. If the compressor were bad, wouldn't it be noisy?
I had a small leak ('89 Saab, R12 $$$$) & the shop put fluorescent dye in it. The leak was slow, so it took a couple months to leak out. Meanwhile, the dye smears around everywhere, so its not that easy to tell exactly where it's coming from. I got a blacklight, too. Do you know how much other stuff fluoresces in there, anyway?
jrock1234
Jun 4, 2012 12:26 PM
LsVtecFoti
Apr 20, 2008 11:23 PM
el_toro_de_magnifico
Mar 25, 2008 08:04 PM
Nocturnal
Welding / Fabrication
38
Feb 27, 2008 08:04 PM
Rod.
Jun 7, 2005 02:24 PM
