a/c removal problem
Old Oct 5, 2008 | 11:50 AM
xpoisnfreex's Avatar
Default a/c removal problem
is the same belt that is running my a/c also the same belt that is used for my alternator? can anyone else help explain to me a little better how to remove my a/c from my 94 gsr? PLEASE!!!
Old Oct 5, 2008 | 12:23 PM
Default Re: a/c removal problem (xpoisnfreex)
PLEASE ANYONE CAN YOU GELP ME WITH THIS IT WOULD BE GREATLY APPRECIATED!
Old Oct 5, 2008 | 02:41 PM
swgateg's Avatar
the search button is an amazing thing
Old Oct 5, 2008 | 03:02 PM
Default Re: (swgateg)
yeah i did search tough guy, found nothing.
Old Oct 5, 2008 | 03:08 PM
BMXman's Avatar
Default Re: (xpoisnfreex)
the info is out there but it's hard to search because people only type ac or a/c like you have and the search engine doesn't really recognize short terms.
Old Oct 5, 2008 | 03:24 PM
sh4mr0ck's Avatar
Default Re: (BMXman)
No. the belt that runs your A/C is not the same as your alternator belt. There should be three belts coming from your crank pulley: the power steering belt, the A/C belt, and your alternator belt. You can cut the one to A/C safely without worrying about the other two.
I hope this helps you out, good luck!
Old Oct 5, 2008 | 03:33 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (sh4mr0ck)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sh4mr0ck &raquo;</TD></TR><TR><TD CLASS="quote">No. the belt that runs your A/C is not the same as your alternator belt. There should be three belts coming from your crank pulley: the power steering belt, the A/C belt, and your alternator belt. You can cut the one to A/C safely without worrying about the other two.</TD></TR></TABLE>
This is also pretty easy to notice if you look at the belts. But yes, the a/c has it's own belt.
Old Oct 5, 2008 | 05:14 PM
Default Re: (CleanLikeJdm)
thats what i thought guys buti couldn't tell and snipping a belt is a big step if you not 100% sure what you are doing. thanks though this akk helped alot.
BNSTKSI
Aug 8, 2011 11:08 AM
CALC!_JUST_du_IT!
Jun 10, 2008 12:55 PM
flatblack-h22
Aug 17, 2006 05:53 PM
Beau Gotti
Apr 24, 2006 06:10 PM
shorto85
Oct 12, 2005 01:39 PM
