A/C question
Old May 6, 2003 | 09:13 AM
mattL's Avatar
Default A/C question
My A/C suddenly stopped blowing cold, i'm not too familiar with A/C systems so i dont know what to check. All the belts are still on, but i noticed that when i turn it on the fan that is attached to the radiator doesnt turn on, its supporsed to turn on right? Any suggestions what to check? thanks
Old May 6, 2003 | 11:42 AM
JimBlake's Avatar
Default Re: A/C question (mattL)
My first guess would be if your refrigerant is low (leaked out) then the low-pressure interlock won't let you run it. If you don't have the gauges, then take it to an A/C place to check it out.
Old May 6, 2003 | 11:53 AM
TurboedGSR's Avatar
time to recharge (have them look for any leaks also)
the fans come on when the engine heats higher than normal. example while sitting in traffic/stoplight with little air flow
mattL's Avatar
Default Re: A/C question (JimBlake)
i hope its just that, i just found it strange that it blew cold one day and totally stopped the next.
Old May 6, 2003 | 12:18 PM
King_j's Avatar
i take it this is for your 95 gsr, if so then the system is r-a34a and you can buy a recharge kit from checkers or autozone for like $25. it comes with refrigerant, oil, and guages. you will be using the low preassure side of the a/c system which is the zozzle right between the raidator and the valve cover, it should have a blue cap that is screwed on.
Old May 6, 2003 | 12:33 PM
mattL's Avatar
Default Re: A/C question (King_j)
Ok, i'l look into that. Yeah i'm dyin, you cant be in Fl without ac.
Old May 6, 2003 | 12:34 PM
2001gsRguy2's Avatar
you can buy a recharge kit just for 25 bucks? wow thats a good deal..i heard its like 80 bucks to refill your freon
Old May 6, 2003 | 12:37 PM
evolve's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">time to recharge</TD></TR></TABLE>
Old May 6, 2003 | 12:57 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattL &raquo;</TD></TR><TR><TD CLASS="quote">... i just found it strange that it blew cold one day and totally stopped the next. </TD></TR></TABLE>
Recharge, but look for leaks too. The reason it stops suddenly, is that when the pressure gets low, the low-pressure interlock switch just shuts it down. If you bypass that interlock, then it just gradually gets less effective. But that way you destroy your compressor.
Old May 6, 2003 | 05:07 PM
mattL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">
ok cool, that makes sense thanks
Gelignite
Jul 13, 2015 04:22 PM
opg5009
Jun 11, 2007 08:40 AM
Blown383
May 10, 2007 09:18 PM
Yellow Submarine
Jun 21, 2006 03:19 AM
Milano4
Jun 9, 2004 12:15 PM
