A/C doesn't work anymore
Old Jun 8, 2004 | 03:50 PM
Andrew 825SM's Avatar
Default A/C doesn't work anymore
While installing my radiator, was gonna remove one of the pressure hoses since it was getting in the way betweent he radiator and turbo. But when I was unscrewing it, being dumb as I am, I forgot that the hose was under pressure and some freon sprayed out. Also, when installing the radiator, I could not mount the condenser fan onto the radiator. I am wondering is my AC not cold because of teh condenser fan or some of the freon that leaked out of the hose
Old Jun 9, 2004 | 03:53 AM
JimBlake's Avatar
Default Re: A/C doesn't work anymore (Andrew 825SM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrew 825SM &raquo;</TD></TR><TR><TD CLASS="quote">... I am wondering is my AC not cold because of teh condenser fan or some of the freon that leaked out of the hose</TD></TR></TABLE>Or both...
Measure AC pressures to tell whether you let too much out (you probably did). If the pressure is really too low, the low-pressure switch won't let the compressor engage.
Only then you can find out whether you really need the fan. You might have to get a pusher fan.
gosslingk
Nov 22, 2015 01:57 PM
cn_bb
Aug 9, 2012 11:00 AM
XxRoCkMaNxNEOxX
Oct 2, 2005 07:24 PM
jazz215
Aug 23, 2003 10:48 PM
