a/c compressor
Old Sep 12, 2004 | 06:05 AM
mrxracing's Avatar
Default a/c compressor
Has anyone else had problems getting the top bolt out of the a/c compressor or is there some sort of trick to it?
you know the one that sits right above the compressor and is deep in there?
Is this a special honda tool or what? There is maybe a 1/4 inch of clearance.
I'm trying to pull the engine with out taking out the tranny but the compressor shaft is hitting the frame as i lift it?
I'm sure maybe someone has run into this problem, Thank you
95 Ls
Old Sep 12, 2004 | 06:32 AM
W.O.P.'s Avatar
Default Re: a/c compressor (mrxracing)
4 bolts thats it. nothing hard whe i took mine off. well you have the A/C lines as well. no tricks just turn it counterclockwise
Old Sep 12, 2004 | 07:29 AM
mrxracing's Avatar
Default Re: a/c compressor (1quickLS)
unless mine is a special edition. there is one bolt that sits under a lip on the top that goes into the side of the block a 14mm. I have some severe bend wrenches that have about and inch l bend that fit but they are standard.. but right on the very top you have the hose plate with four allen heads and right in towards the block is this bolt??
Old Sep 12, 2004 | 07:37 AM
W.O.P.'s Avatar
special edition has nothing to do with it dude
Old Sep 12, 2004 | 07:44 AM
mrxracing's Avatar
i was joking!
Dannyx321
Sep 15, 2012 02:13 PM
BoOsTiN Dc2
May 3, 2005 02:35 PM
DavidR
Jun 23, 2004 11:01 AM
incogNitto
Jan 7, 2003 10:41 AM
