A/C compressor
Old Feb 2, 2009 | 02:09 PM
808DA's Avatar
Default A/C compressor
my air conditioning is not getting cold even after i recharged it. i checked the lines if its leaking and there are no leaks. how can you tell if the A/C compressor is bad? thanks
Old Feb 2, 2009 | 02:13 PM
bunnyhatch93's Avatar
Default Re: A/C compressor
when you turn on the ac do you hear the clutch turn on. you will hear a click.
Old Feb 2, 2009 | 04:04 PM
'00_GSR/R's Avatar
After the click your idle will go up to compensate for the compresion of the pump. If you can hear it drawing power off of the motor than the pump has good compresion.
Old Feb 2, 2009 | 04:08 PM
racebum's Avatar
if it is the compressor you won't have a hard time getting a working one on the cheap
Old Feb 2, 2009 | 05:12 PM
808DA's Avatar
thanks for all the replies. i will check as soon as i get home.
by the way, if i need to change compressor, can i use any b series compressor?
drpapijr196
Jun 15, 2011 02:17 PM
dx7alex
Jun 24, 2009 07:17 PM
Civic Racer X 7
Aug 23, 2007 08:42 AM
freaker
Aug 10, 2005 06:09 PM
