broken stud
Old Mar 23, 2009 | 03:55 PM
210southstar's Avatar
Icon3 broken stud
Just noticed my right rear has a broken one . Anyone know of rotors sold with tha studs on them r where to get tha complete part. would it be called tha drum?
Old Mar 23, 2009 | 04:28 PM
HGZ's Avatar
HGZ
Default Re: broken stud
the rear studs are easy to replace. just take off wheel, unbolt brake caliper and move out of the way, take off rotor (remove the screws), then just knock the studs out of the hub and replace with new ones. then put everything back together.
if you've been driving for awhile on just 3 studs, i would go ahead and replace all four of them to be safe. they're really cheap.
Old Mar 23, 2009 | 04:38 PM
Well i bought tha car bout 4 months ago so since then. It has extended wheel studs its there just wiggles around. Gonna take tire off n see if its just loose.
Old Mar 23, 2009 | 06:39 PM
SFWD 1934's Avatar
If the car has ABS, remember that they only sell the rear bearings with the hubs/abs ring. Depending on how hagard the bearings are, I always suggest replacing them. They are about $140 each without the wheel studs.
Part number 2
http://acuraautomotiveparts.org/acur...s=&view=normal
Jason
sde780
40
May 15, 2012 10:32 AM
killerpenguin21
Nov 14, 2006 12:36 PM
1point7db2
Jun 10, 2006 08:50 AM
CHONCH
22
Dec 1, 2003 09:21 PM
geminis2k
Sep 26, 2002 03:01 PM
