Brakes
Brakes
I recently replaced my front rotors and pads, and now iam hearing a sound that resembles like my rotors are warped even though they are new, only took 2 days of normal driving to start the noise again....can someone help with this
Re: Brakes (skillygil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skillygil »</TD></TR><TR><TD CLASS="quote">I recently replaced my front rotors and pads, and now iam hearing a sound that resembles like my rotors are warped even though they are new, only took 2 days of normal driving to start the noise again....can someone help with this</TD></TR></TABLE>
like they are warped? is it more like a grinding noise or a squeeky noise?
Did you bead your pads in correctly? Any hard stops that might have gotten them hot. It seems funny that you warped rotors already, it shouldn't have happened. I think there was a thread in here about a build up of brake dust causing similar symptoms to warped rotors. I think they said that was the case more often than not. Did you replace you pads? Steering wheel shake under hard braking?
Re: (Doostur)
Factory setup for 98 LS 4 wheel disc. I have also heard the sound under turning in a circle going clockwise. I replaced the bearing, the pads on front, and both front rotors. Please i dont want this to continue to happen, like i said third time since march, with only 4500 miles
icebluecivic21
04-29-2008 10:56 PM
onephatcivic
17
06-13-2004 01:17 PM
