BRAKE PROBLEMS!!! HELP!!!
Old May 1, 2007 | 06:26 AM
acura_integra_87's Avatar
Default BRAKE PROBLEMS!!! HELP!!!
Hey, Im Erik and im new to hondas/acuras, with the exceptions of the NSX i had for a while, anywho, i picked up a special edition 87 integra LS and the brakes like to stay applied after pushing the pedal a couple of times, now, i replaced the rotors, pads, calipers, brake hoses, fluid flush, and new master cylinder. Being that there is nothing else in the brake system besides the proporstion valve, would that be whats bad??? someone help...
Old May 1, 2007 | 08:45 AM
g0tgot's Avatar
Default Re: BRAKE PROBLEMS!!! HELP!!! (acura_integra_87)
i do understand that you can only use certain fluids from honda, jlike the power steering fluid and manual transmission fluid......most likeley the compression of the brake fluid that you are using could be the problem if it is not from honda and it will warp certain seals and gaskets too.......
Old May 1, 2007 | 08:58 AM
Default Re: BRAKE PROBLEMS!!! HELP!!! (g0tgot)
gaskets and seals on what? i think its the proportion vavle thats the problem...
tazz29
Jul 9, 2008 10:52 AM
pinks11
Oct 15, 2007 10:05 AM
92integraVTECgsr
Jun 7, 2006 02:57 PM
XzzYzzX
Oct 5, 2004 08:27 PM
REDBARON
Jul 16, 2001 11:05 AM
