brake problem please help
i have a 1994 acura inegra ls with abs and when i push the brakes it starts to fade and every week i have to put more fluid in the abs resevoir i have checked all the calibers and the brake lines there is no leaks in them
Get in there and check all around your master cylinder and fittings there. Then trace the lines to your prop valve. Then to your abs module, and on to your lines. Get under the car and trace them all the way to your calipers. Check in and around your pads, make sure your pistons haven't blown their seals. You've got a leak somewhere (obviously), and the air getting into your system is causing your shitty pedal. Get to checking, that ****'s dangerous to you and others.
qestion i notice that some people have a red cover over there abs filler i do not have that part of it would that cause a leek
