brake problem
Old Jul 11, 2013 | 02:37 AM
hteg12's Avatar
Default brake problem
Lately my brakes don't seem to be working the same. As I brake, It seems to go in more than it should normally. I can push it in all the way and it won't stop my car completely, just slow it down. Since this happens, I basically have to pump my brake to slow down and stop all the way. I've asked around and people have told me that it can that my master brake cylinder is going out or it could be my cap for my brake fluid. Also, that i might just need to bleed my brake lines.
Any suggestions or ideas about what it might be?
Old Jul 11, 2013 | 03:57 AM
m4xwellmurd3r's Avatar
low fluid, bleed the brakes, leaky calipers, bad master cylinder, worn out pads, cracked brake line.
those are all possible causes for squishy pedals. oh forgot one, leaky weep hole on the proportioning valve
Posted from Honda-tech.com App for Android
Old Jul 11, 2013 | 08:48 AM
B_Swapped93's Avatar
Default Re: brake problem
^yes
OP inspect what you can visually(which is everything listed). as for bleeding the brakes look for a "DIY" it's on here.
Old Jul 18, 2013 | 05:13 PM
hteg12's Avatar
I bled the brake lines and it did help a bit . But I do think its my master brake cylinder. So I'm just going to replace it. My abs light came on though and I pulled the code which was 4-1, and it seemed to be my right front sensor. I cleaned the sensor but the light came on. I still got the same code, any thoughts?
fantasyboi_k
Feb 15, 2014 12:45 PM
da1lydr1ver
Mar 26, 2012 06:25 PM
Civic-Kids
Nov 24, 2009 05:07 AM
NuclearB18B
Jul 5, 2005 07:21 AM
Chubakon
Jul 29, 2004 08:56 AM
