brake problem. HELP!!!
Old Jul 27, 2004 | 08:00 PM
Chubakon's Avatar
Default brake problem. HELP!!!
wat's wrong with my brakes. when i brake i have to press it all the way down and it fêels like there's no pressure.. n the pads are gơod, no squêek.
could it be the pump from the brake master cylinder?
plz help
Old Jul 27, 2004 | 08:03 PM
JDMThoughts's Avatar
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
Default Re: brake problem. HELP!!! (94dc-er)
Did you just do your brakes? If you did, did you properly bleed your braking system. If you did that correctly did you properly bed the new pads. Your master cylinder might be shot, if everything else checks out. Check your brake lines and make sure none of them are worn out or are pinched, that will make mushy pedals as well.
Old Jul 27, 2004 | 08:20 PM
IVI's Avatar
IVI
do you suspect air got into the lines?
if so then that can be ur problem
explain further then i can go into further detail.
Old Jul 27, 2004 | 09:36 PM
Chubakon's Avatar
Default Re: brake problem. HELP!!! (IVI)
well, i just bought this car. there's no holes in the brake lines. n the pads are good. i ask my friend, n he said it might be the pump.
any 1 have ny opinion???
Old Jul 27, 2004 | 10:06 PM
SYTFU Tommy.'s Avatar
low on brake fluid?
Old Jul 28, 2004 | 09:40 AM
Default Re: brake problem. HELP!!! (tngay)
Check your master cylinder, and just because you bought the car doesn't mean something couldn't have failed.
Old Jul 28, 2004 | 07:08 PM
Chubakon's Avatar
Default Re: brake problem. HELP!!! (JDMThoughts)
well, i checked fluid, n it's gơod.
when i brake it gets softer n softer n the car doesnt stop that much.
should i blêed the fluid then put in new fluids?
any1?
Old Jul 28, 2004 | 07:28 PM
DB8_TEG's Avatar
Check and see if there is any brake fluid against the brake booster that will let you know if the master cylinder is leaking. If not then bleed them to make sure no air is left in the lines.
Old Jul 29, 2004 | 08:56 AM
Default Re: brake problem. HELP!!! (DB8_TEG)
hteg12
Jul 18, 2013 05:13 PM
Civic-Kids
Nov 24, 2009 05:07 AM
USDM-EK4*
Apr 4, 2008 07:50 PM
mingchi69
Jun 21, 2003 11:47 AM
ls_draco
May 10, 2002 08:47 PM
