Brake install help...
Old Sep 30, 2004 | 04:42 PM
xyooj's Avatar
Default Brake install help...
I just put new pads and rotors on the front. Had a fun time drilling the 6mm rotor retaining screws. First time, the passenger side was burning after road test.
Second time, sanded the pads down. Reinstalled everything. Still same results, burning. I went out and got a reman caliper and installed everything. I know that its gonna burn again because the wheel was very hard to turn. Any imputs? What is a callaps brake line? I have been working on it for a week now. General matinece has turn out to be a project.
Summary
new pads and rotor. Installed correctly. Passenger side burns. Got new caliper and blead the system. Still hard to turn the passenger side wheel. Help?
Old Oct 1, 2004 | 04:25 AM
JimBlake's Avatar
Default Re: Brake install help... (xyooj)
Pad retaining clips in wrong?
Caliper slide-pins seized?
New pads wedged too tight into caliper bracket? (I usually have to file a bit off the ends - about the thickness of the paint.)
Old Oct 1, 2004 | 07:02 AM
xyooj's Avatar
nope...new pins and boots... everything done right. I think its gotta be the brake hose. "Brake hose collapsed" fluid can go in but not back out. I hope a new hose works. Damn wasted money on a new caliper...any one want a caliper?
Old Oct 1, 2004 | 07:54 AM
JimBlake's Avatar
Default Re: (xyooj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xyooj &raquo;</TD></TR><TR><TD CLASS="quote">"Brake hose collapsed" fluid can go in but not back out.</TD></TR></TABLE>A little unusual, but certainly that's possible. Hope it works. Gonna replace all the hoses? They're all the same age...
Old Oct 1, 2004 | 07:55 AM
integra15's Avatar
Default Re: (xyooj)
What do you mean by "burning", like a burning smell? Are the pins sliding smoothly? You could always bleed the brakes and see if that helps.
Old Oct 1, 2004 | 06:27 PM
xyooj's Avatar
Yes..burning..literally the pads are burning(smoking). Pins are sliding...its all new. Update. INstalled new brake hose. Same problem. Gonna give it one more try 2morrow before i send it to the shop on sunday. To frustraded.
gsr1289
Aug 18, 2006 01:05 PM
P@@RB@Y
Mar 5, 2006 06:06 PM
athoughts
Nov 17, 2005 03:12 PM
94gsr_vtc
Mar 30, 2005 06:34 PM
el_Presidente
Feb 12, 2003 09:08 PM
