brake conversion
Old Sep 12, 2007 | 06:41 AM
keep_up's Avatar
Default brake conversion
i got a 92 intgera rs so its got no abs. i also have a 94 civic dx with no abs. would it be possible to convert my rear drums on my civic to my rear integras disc brakes? also would the front calipers bolt up as well? what is needed so i can swap this? will it directly bolt up?
Also i remember reading sumones post onetime and this guy knew a shitload about brakes maby he can help me out!
Old Sep 12, 2007 | 08:39 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: brake conversion (keep_up)
the trailing arms will bolt up. you may have to get EG/EK/DC calipers. I dont think the DA lines will work (hence, making the calipers not work). Not sure if the E brake cables will work
Old Sep 12, 2007 | 10:27 AM
keep_up's Avatar
Default Re: brake conversion (B serious)
ok how about just the front calipers and rotors then will they just bolt up?
Old Sep 12, 2007 | 10:36 AM
St Jimmy's Avatar
* B A N N E D *
Pic links are broken but here is a nice step by step write up on how to convert your drums.
https://honda-tech.com/zerothread?id=812062
And yes the fronts will bolt up the only issue you might have is clearances for the wheel to fit on, but all you have to do (if they wont fit) is buy some wheel spacers at your local auto store.
Old Sep 12, 2007 | 11:30 AM
keep_up's Avatar
Default Re: brake conversion (St Jimmy)
can sumone plz comfirm if i need wheel spacers or not, and idf the front brakes will just bolt up with no problems.ty
Old Sep 12, 2007 | 12:27 PM
St Jimmy's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keep_up &raquo;</TD></TR><TR><TD CLASS="quote">can sumone plz comfirm if i need wheel spacers or not, and idf the front brakes will just bolt up with no problems.ty </TD></TR></TABLE>
We cant confirm if you dont tell us what kind of wheels you have
Old Sep 12, 2007 | 06:00 PM
keep_up's Avatar
stock steel 14 inch
Old Sep 12, 2007 | 09:35 PM
keep_up's Avatar
bump for a bday boy 18 whooooooooohooooooooooo
Old Sep 13, 2007 | 07:15 AM
St Jimmy's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keep_up &raquo;</TD></TR><TR><TD CLASS="quote">stock steel 14 inch</TD></TR></TABLE>
Yes they will fit under 14inch steelies (same wheels some of the integras came with)
Happy Birthday.
Old Sep 13, 2007 | 07:45 AM
keep_up's Avatar
alright thanks for the info and bday welcome. im gunna switch the calipers and rotors now. how about the back brakes from the 92 integra to the 94 civic dx coupe. if i put the intgeras rear brakes lines proportioning valve and master cylender and the arm with the disc brake would it bolt right up to my civic and work? oh yah and the ebake cable.
05Bodyssey
Sep 5, 2017 12:42 PM
Whatislove
Honda Civic (2001 - 2005)
12
Nov 9, 2010 06:59 AM
styll_rydin
Mar 29, 2009 09:14 PM
keep_up
Sep 12, 2007 07:43 AM
akteamster
Jul 25, 2005 09:34 AM
