ICM (igniter) gives the tach signal, not the speed signal. speed signal is provided by the VSS (vehicle speed sensor) attached to the top rear portion of the transaxle.
If the OP has a 90-93 integra. The speedo cable probably needs to be cleaned and relubed up. they will stick and cause a scratching noise as described.
