boost problem on 94 gsr
Old Nov 4, 2009 | 03:31 PM
1994gsrturbo's Avatar
New User
Default boost problem on 94 gsr
Ok so my car has the turbonetics kit on it, i recently installed a new turbo because my old one was bad, now whenever i hit boost it spools up to the normal 10lbs and the rps die to about 2k, it will then pick back up, it almost acts like it runs out of fuel??? what could be the problem? car was running fine before the first turbo went bad????
Old Nov 4, 2009 | 05:01 PM
chocolatesk8er10's Avatar
Default Re: boost problem on 94 gsr
Are you running a stock map sensor? Cause if so then you could be hitting 11ish lbs and the map sensor could be out of its range and use ignition/fuel cut. Just a suggestion
Old Nov 4, 2009 | 08:52 PM
ILS_09's Avatar
I need to the know the whole list of mods for your turbo setup.It will help narrow down the problem and also all the accessories you have not changed since the installation of your new turbo.
Old Nov 4, 2009 | 08:56 PM
TonySemi's Avatar
Do you have the "missing link" ? It sounds like a MAP problem to me. New turbo prob makes more boost.
Old Nov 5, 2009 | 06:30 PM
hmoobhero's Avatar
definetly needs a retune. stop going into boost. you will mess up your new turbo. could be alot of things. is the new turbo the same as the old one?
jlows923d
Oct 2, 2007 11:05 AM
nicktagz
Sep 25, 2006 10:49 AM
aubry588
Feb 24, 2006 09:46 AM
wshondaman
Dec 19, 2004 06:36 PM
wshondaman
Dec 1, 2004 09:49 PM
