boost cams?
Old Dec 27, 2007 | 06:50 AM
racereaper7's Avatar
Default boost cams?
what type of camshaft would be good/ add the most power for a boosted jdm b16 2nd gen:
-use the stock b16 cams
-itr cams
-ctr cams
-gsr cams (i heard these would be the best on a b16- http://www.evans-tuning.com/comp3.html)
or
-skunk2 turbo stage 1 cams?
Old Dec 27, 2007 | 07:00 AM
PrinceAli132's Avatar
Default Re: boost cams? (racereaper7)
Search in the F/I section and include archived threads.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by search results &raquo;</TD></TR><TR><TD CLASS="quote">
Your search for turbo cams returned 330 results
Your search for boost cams returned 44 results
Edit - And more info on your build would help as well?
Ali
Old Dec 27, 2007 | 07:10 AM
this is the turbo set up i was going to put in most are from rc auto works:
-mini ram
-2.5 downpipe
-tial waste gate 38mm
-greddy rs bov
-intercooler(rcauto works)
-garrett t3/t4 50 trim
-set up is for a dd with about 250 whp or around there
sorry about that i posted this setup in the fi form and no one posted anything
Old Dec 27, 2007 | 07:14 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racereaper7 &raquo;</TD></TR><TR><TD CLASS="quote">
Honestly, no one probably asnwered because your question has probably been asked several times before.
Just search, you'll find more information. And from there if you still have more questions on specific cams for your setup then you can post and make a thread asking for more clarification.
Ali
Old Dec 27, 2007 | 07:17 AM
Default Re: boost cams? (PrinceAli132)
i'll search some more any if i need more help i'll ask again thanks for your help
Old Dec 27, 2007 | 07:21 AM
LL2009's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racereaper7 &raquo;</TD></TR><TR><TD CLASS="quote">this is the turbo set up i was going to put in most are from rc auto works:
-mini ram
-2.5 downpipe
-greddy rs bov
like said before this has beem cover 100 times try searching and alot of reading, but for this set up u might want to run with a 3inch down pipe and GSR or ITR cams will be good enough to reach ur goal u can reach that hp with b16 cams, but with the gsr or itr cams it will breath better....
hellakapps
Oct 18, 2007 01:05 PM
97turboteg
Dec 15, 2005 07:52 AM
GWInquisitor14
Sep 7, 2005 06:25 AM
Nextelbuddy
Jun 29, 2003 05:48 AM
