Bolt out kit
Old Jan 15, 2011 | 05:11 AM
LavishTheKid's Avatar
Default Bolt out kit
i bought a bolt out 5 pc set and it has a 14mm size and i want to know if i should hammer the 14mm on my stripped lca bolt or use the 15mm bolt out remover.
Old Jan 15, 2011 | 05:43 AM
94VTEC2TONE's Avatar
Default Re: Bolt out kit
How tight is the 15? probably go with the 14 if it will hammer on, want the tightest grip possible
Old Jan 15, 2011 | 06:03 AM
the 15mm is tight but when its on you can move it to the left or right a ittle bit.
Old Jan 15, 2011 | 10:19 AM
nospoolDC2's Avatar
if its already stripped your going to want the tightest possible fit. if the 15 has some play in it, go ahead and hammer the 14 on so you dont make it worse.
Old Jan 15, 2011 | 12:18 PM
exactly what he said. with those boltouts u wanna hammer it on so it dont slip, those work very well, just makes ure u get a good breaker bar or have a good length ratchet. goodluck man
Old Jan 15, 2011 | 12:23 PM
nospoolDC2's Avatar
Old Jan 15, 2011 | 05:47 PM
well now i need a bolt out kit that comes with 10-13mm now, cuz i tryed to hammer on the 14mm bolt out socket and now it wont even hang on the head of the bolt.
stevevang
Mar 27, 2016 04:46 AM
LavishTheKid
Jan 15, 2011 02:41 PM
psychotech
Oct 15, 2010 11:56 AM
chochocho
Jul 19, 2004 04:44 PM
hellas
Jan 21, 2003 12:33 PM
