Bogging problem
Old Nov 11, 2003 | 06:27 AM
96lsisslow's Avatar
Default Bogging problem
New to the board. Cant seem to find any help on other websites so I found this one. I was driving home from school yesterday (Had no problem with the car on the way there, filled up the tank and went) and the car started bogging horribly bad. If I barely touched the gas it wouldn't bog but as soon as I gave it just a little it was bogging uncontrollably. Halfway home the car quit doing it. Then I parked at a friend's house for an hour or so jump in and the problem is back. Any help would be appreciated
Old Nov 11, 2003 | 08:02 AM
P1mpSlap's Avatar
possibly a bad batch of gas
I say bounce her off the rev limiter a couple of times and it'll fix it.
Old Nov 11, 2003 | 08:11 AM
roadrunner's Avatar
Intermittent problem after refueling - first, check that your fuel cap is on tight. Did the Check Engine light come on?
You may also want to check that your spark plug wires are snug.
Old Nov 11, 2003 | 12:22 PM
BrownGSR's Avatar
Default Re: Bogging problem (96lsisslow)
o2 sensor, happend to me before
Old Nov 11, 2003 | 02:18 PM
CNSK's Avatar
Default Re: Bogging problem (BrownGSR)
check o2 sensor, plugs, bad gas, run diagnostic test
Old Nov 11, 2003 | 02:53 PM
SIanara's Avatar
what they said... could be some watered down gas.. what brand do u purchase?
Old Nov 11, 2003 | 02:58 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: (vteGraGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteGraGSR &raquo;</TD></TR><TR><TD CLASS="quote">what they said... could be some watered down gas.. what brand do u purchase?</TD></TR></TABLE>
hopefully not BP.. their gas is the freaking worst!
Old Nov 11, 2003 | 03:02 PM
LSTEG96's Avatar
Default Re: (Hatchy-Ownzjo0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchy-Ownzjo0 &raquo;</TD></TR><TR><TD CLASS="quote">
hopefully not BP.. their gas is the freaking worst! </TD></TR></TABLE>
can i blame my car being hella slow on this then??
Old Nov 13, 2003 | 06:05 AM
96lsisslow's Avatar
Default Re: (LSTEG96)
Problem solved. Just enough moisture in on of the plugs to make it bog.
Old Nov 13, 2003 | 08:47 AM
SIK IN DA HED's Avatar
New User
Default Re: (96lsisslow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96lsisslow &raquo;</TD></TR><TR><TD CLASS="quote">Problem solved. Just enough moisture in on of the plugs to make it bog.</TD></TR></TABLE>
how did you get moisture on your plugs?
Old Nov 13, 2003 | 08:51 AM
96lsisslow's Avatar
Default Re: (SIK IN DA HED)
Was recently in a wreck, hood was buckled and it rained that night. Guess some rain got in there.
gtec8285
May 31, 2008 06:04 AM
OriginalFive
Honda S2000
18
Jul 18, 2005 12:34 PM
kjou2001
Jun 2, 2004 05:36 PM
0554
Feb 23, 2004 11:19 AM
mickey513
Apr 6, 2003 01:10 AM
