Hey guys,
My dad just bought a 91 integra. It has an automatic transmission and I recently received a call from him telling me that the instrument panel had the outline around the D3 icon blinking at random times. Do u guys know what the problem might be?
Thanks in advance.
Thanks in advance.
Thanks in advance.
a bad ground caused a blinking d4 light in my 2000 lsOriginally Posted by bazoOKA_ TOoth
Hey guys,My dad just bought a 91 integra. It has an automatic transmission and I recently received a call from him telling me that the instrument panel had the outline around the D3 icon blinking at random times. Do u guys know what the problem might be?
Thanks in advance.
Quote:
Where was that ground on your car? I want to find it on my car.Originally Posted by follie gatts
Quote:
are you also showing a CEL? mine blew a fuse each time the AT tried to shift. the incomplete ground was the negative battery terminal to the chassis.Originally Posted by bazoOKA_ TOoth
use a voltmeter that can check for continuity between two points on a circuit. use it on the the 3 major grounds from (battery, valve cover and transmission) to chassis.
