Bleeding brakes
Old Jul 7, 2008 | 04:20 PM
CourtesyBullet's Avatar
Default Bleeding brakes
I searched, but I've tried everything that I read and nothing works, so I think I need a little more personal help. I have a 97 DC4, and after I swapped the engine I have zero brake pressure, the pedal goes right to the floor. I tried bleeding all I could in the order I read when I searched and still absolutely nothing. Please help.
Old Jul 7, 2008 | 06:36 PM
Kr4nG's Avatar
did you bleed the brakes correctly? first make sure there is enough fluid. you always want to bleed the caliper that is furthest away from the master cylinder. so the back right then back left then front right then front left. make sure you vacuum hose doesnt have a hole or anything too.
Old Jul 21, 2008 | 03:10 PM
Default Re: (Kr4nG)
Sooooo, I tried bleeding them numerous times and wasted an entire container of brake fluid, and the brakes feel decent until the car turns on and all pressure is instantly lost. I really need some suggestions, I can't afford to take this heap to a shop.
Old Jul 21, 2008 | 03:48 PM
hon2984's Avatar
Default Re: (CourtesyBullet)
check for leakage any where and every where. did this problem show up slowly (pre and post swap) or immediatly after the swap?
if u have the car started and try to pump the pedal does it have pressure and then go to the floor? if so its leaking fluid. it kinda sounds like the master cylinder.
are you doing this by your self with nobody pumping the brakes?
Old Jul 21, 2008 | 04:41 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Default Re: (hon2984)
Replace the master cylinder, then report back.
Old Jul 21, 2008 | 06:36 PM
non-VTEC's Avatar
Default Re: (PhantoM.DA)
sounds like the master cylinder took a crap........
Chilloutdamn
Nov 4, 2008 03:24 AM
josh564738291
Sep 17, 2008 10:32 AM
civic89si666
Jul 8, 2007 06:37 PM
phyzJunkieCivic
Aug 13, 2006 10:25 PM
EGhatched
Mar 26, 2002 01:52 PM
