Big Timing Problem in a boosted LS
Old Jun 6, 2006 | 04:19 PM
prockish_96teg's Avatar
Default Big Timing Problem in a boosted LS
My first problem with my boosted car and its not even the tranny (Go figure)... I was driving like a couple of weeks ago when all of a sudden my car shut off. I took off my valve cover and noticed my INTAKE CAM was like 90 degrees advanced traced it to a locked up Water Pump. Bought a new timing belt and water pump drove fine for like 5 days then my car shut off again. Once again i noted the INTAKE CAM advanced like 10 degrees.(Aquired NEW CAMS AND CAM GEARS so I put those in while i was at it.) I put EVERYTHING back to TDC and put the timing belt belt back on. Started first try and within 10 seconds it shut off again. TIMING SKIPPED AGAIN. I am running into a dead end ANY HELP would be much appreciated.
Old Jun 6, 2006 | 04:56 PM
SlamminS85's Avatar
Default Re: Big Timing Problem in a boosted LS (prockish_96teg)
it might not be your timing belt or your water pump... might be your DISTRIBUTOR, its connected at the otehr end, if tis encountering a lot of resistance and then snappinf forward or something, i dont know
Old Jun 6, 2006 | 05:49 PM
akstunt600's Avatar
maybe bad tensioner pulley/wheel, spin it make sure its smooth.
new timing belt??? sometimes they stretch just a tiny bit< espescially if ur h20 pump siezed but, i doubt you would have reused that belt again well at least i hope you didnt
its not a good to take any chance with a B
how much tension header side< there should be NO slack
i find i have to play with b-series alot to get what i feel is a proper fit.
sideswiped
Feb 7, 2009 09:48 PM
TegraD
May 25, 2008 07:59 PM
Contender25
Jun 9, 2005 07:10 PM
djtech
Aug 21, 2004 07:14 AM
HybriDNA
Mar 29, 2003 09:14 PM
