big problem
Old Dec 18, 2006 | 09:52 PM
bluelsvtecda9's Avatar
Default big problem
heater,radio,and cig lighter wont work wit car running but only when off wit key on on 1 postion
Old Dec 18, 2006 | 11:58 PM
qfast817's Avatar
Default Re: big problem (bluelsvtecda9)
check your fuses, or you could have a short on your ign switch
Old Dec 19, 2006 | 02:05 AM
god.loves.ugly
Guest
Posts: n/a
Default Re: big problem (qfast817)
that is a big problem.
check the fuses.
have you done anything to the car lately?
repair any thing?
Old Dec 19, 2006 | 02:22 PM
no didnt do anything to da call tried to run radio striaght to fuse but still wont work with car running thats weird. changed switch,fuse box and ignition harness dont know what it is everything works with key on but not running
Old Dec 19, 2006 | 02:42 PM
g2daturbo's Avatar
i would def say ignition switch or a bad ground somewhere... for the radio to work it needs power and ground,....check and see what you have and what you dont so u know where to look....let me know
Old Dec 19, 2006 | 04:26 PM
da heater,radio,and cig lighter all dont work only when car is off any relays or curcuit breakers that could be da problem by da way its a 92 acura integra ls
Old Dec 19, 2006 | 04:31 PM
jdm_bones's Avatar
Check your harness, where all the fuses are in side the car under the dash, make sure all harness clips are on properly, and not lose...
civicgsrb18
Jan 4, 2010 04:48 PM
raiden571
Apr 6, 2008 02:05 PM
EK SQUAD 425
Aug 6, 2006 07:29 AM
Sublime95
Nov 16, 2005 07:32 PM
mericbe
Feb 12, 2004 10:09 AM
